For the attention of Sean D,
I tried to answer our recent conversation in the PM area but sadly the computer says No! we this message anyway
"You have reached the limit for number of private messages that you can send for now. Please try again later."
not sure what to do with the response I had after spending quite time doing some testing my end.
Solved! Go to Solution.
thanks @NeilO I'll give it another try
Thats got it it worked this time many thanks for helping out.
@unwina no problem, I momentarily turned off your private messages and turned it them on again just to be sure 😀
