unwina
Expert
Message 1 of 4
For the attention of Sean D
For the attention of Sean D,
I tried to answer our recent conversation in the PM area but sadly the computer says No! we this message anyway
"You have reached the limit for number of private messages that you can send for now. Please try again later."
not sure what to do with the response I had after spending quite time doing some testing my end.
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: For the attention of Sean D
Sorry about that @unwina I'll let @SeanD  know this has happened, if you try again now it should work as we've seen this happen before and it usually sorts itself after a few mins.
unwina
Expert
Message 3 of 4
thanks @NeilO I'll give it another try
Thats got it it worked this time many thanks for helping out.
NeilO
Moderator
Moderator
Message 4 of 4
@unwina no problem, I momentarily turned off your private messages and turned it them on again just to be sure 😀
