Message 1 of 3
Getting Connected to Full Fibre
Hi, I know what I'm going to ask is not a BT issue but maybe someone can help.
Openreach will soon be running fibre to a caravan park across their private open land. It'll be passing within a couple of metres of my house. I've been told the caravan park will be funding the run across this land.
I'd obviously like to be connected but can't find a way on the Openreach website to ask the question. Should I contact the caravan park or is there some other way of registering my interest?
2 REPLIES 2
Message 2 of 3
Re: Getting Connected to Full Fibre
How do you know the caravan park is getting ‘fibre’ , and on what basis is it being provided ?
If this location is getting a fibre leased line , that is not the same as native FTTP , so no way for you to be included, if the location is getting FTTPod , then like a leased line they are potentially paying towards this network being provided ( something not done on a native FTTP rollout ) , and although some near neighbour could benefit, it’s not likely in your  situation .
An example of FTTPod benefiting neighbours, would be where someone pays for FTTPod for their address , and everyone on the same distribution point ( for simplicity sake a telegraph pole ) also benefit, because the network provided takes those immediate neighbours into account , others neighbours , even if extremely close but not  immediate neighbours , ( in this example not served from the same pole )  , wouldn’t benefit.
It could be a FTTP CFP , (community funded project ) , again if you were not canvassed about being included ( as the community pay towards the installation of the network ) it’s not likely to include your property, basically if you were not asked if you would be prepared to contribute, in many cases these contributions are covered by DCMS ( Government ) vouchers / grants .
So hopefully, although it may seem obvious to you that if the ‘fibre’ runs past your home , you must be able to benefit in some way , that’s an overly simplistic view, and there isn’t a way for you to enquire referencing this caravan park ,  the option open to anyone , of contacting Openreach and asking about FTTP availability in your area is available to you.
Message 3 of 3
Many thanks. Doesn't sound promising.
