Message 1 of 34
How the heck do you view the forum index???
So since I last came here things seem to have changed. YOu used to be able to easily see the list of all the forum boards/sections. But not anymore> How do I see the various sections laid out so that I can pop into each one...broadband, email, billing etc??
33 REPLIES 33
Message 2 of 34
Re: How the heck do you view the forum index???
Look in the top left, and click on the three black bars, and you will get a list of boards.
Distinguished Guru
Distinguished Guru
Message 3 of 34
I don't see that menu, KB, on either Firefox or IE, whether I log in direct or from MyBT.
Message 4 of 34
That is odd, I see it on all web browsers and at the top left of every page.
Message 5 of 34
Very odd:-
I always view at 125% zoom on IE11. It gives a better screen width usage, and the font display is larger.
If the zoom is set to 100%, then the  bar icon for the forum index "goes away".
Not tried this on Firefox yet..
Message 6 of 34
@Ribblelancs wrote:
Very odd:-
You will also notice at 100% zoom that the topic sections are shown accross the top. So you click on the required header.
Message 7 of 34
I'm using MS Edge and I don't see that menu button either??
Message 8 of 34
when I use edge on pc and go to forum I can see the heading across the top
Message 9 of 34
The bar icon will appear regardless of zoom settings so long as less than the full page width appears in whatever browser  you have open, instead of stacking the horizontal menu, it gives you the icon.
Message 10 of 34
That is what is shown on what would have been the "mobile" version when viewed on smaller screens. What size of screen are you using?
