ZooBurner
Message 11 of 34
Re: How the heck do you view the forum index???
If your browser window is not opened wide enough to view the whole horizontal menu, the icon will be shown instead.
It has nothing to do with zoom settings, other than how that would in turn effect wether you browser window size can accomodate all the horizontal menu.
NeilO
Moderator
Moderator
Message 12 of 34
Hi everyone,
Depending on your screen size or your browser zooming preferences the menu index will adapt to suit your screen. If I zoom in to 110% or more the menu changes from a banner across the top of the page into the three line menu icon.
Cheers
Neil
pottyperson
Distinguished Guru
Distinguished Guru
Message 13 of 34
Yes, going to 100% does the job. It also removes the irritant of menus opening if you inadvertently hover on one of the headings.
Retrovertigo
Message 14 of 34
 It's a shame it can't display both, as the drop down menus are a step back from how the forum used to be laid out imo. Thanks for clearing this up though 🙂
oldles
Message 15 of 34
imjolly
Message 16 of 34
you can see all the headings across the top of page so no need for 3 bars
busterboy1
Expert
Message 17 of 34
First of all apologies for bringing this subject up again BUT.....
Using Microsoft Edge browser at my default 100% I cannot see / access the 3 lines to access the board index.
But I have to zoom in to 175% to see them which isn't normal viewing on my 27 inch monitor.
Am I missing something somewhere.🙄
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
imjolly
Message 18 of 34
all the headings which you get from the '3 bars' are across the page below the BT purple banner and only when you zoom in to 150% or higher (depending on monitor size) do you get the 3 bars as the headings line now disappears due to magnification
Carlusha
Recognised Expert
Message 19 of 34
@Keith_Beddoewrote:
That is odd, I see it on all web browsers and at the top left of every page.
Me too!
busterboy1
Expert
Message 20 of 34
Just as you say it works at 175%but my viewing is 100% which works for every site on the internet I can see all pages in their full.
@Carlusha  What is you're normal viewing percentage and do you have to zoom in to 150% or more to see the menus the same.?
