Rob364
Message 21 of 34
Re: How the heck do you view the forum index???
I don't see the 3 bars in FF78.0.2
The headings have just gone onto 2 lines.
I do get the 3 bars in Edge Version 83.0.478.64
Both are 64 bit
Edit  Apologies I evidently missed some posts when I looked at this. The FF was at 200% and edge at 150%
I normally view at 110% so never see the 3 bars unless I use my mobile
busterboy1
Expert
Message 22 of 34
I'm using Microsoft Edge 44.19041.1.0
Fact is when I open Internet Explorer it's just the same.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
imjolly
Message 23 of 34
Is that an android version of edge as my version currently is 45.05.4.5036 as my windows version is  84.0.522.40 (Official build) (64-bit)
busterboy1
Expert
Message 24 of 34
Not that I know of, was installed once I updated when I re-Installed Windows the end of last year.
It's on my Gigabyte Sabre 17 Laptop hooked up to a 28 inch monitor that I use daily.
busterboy1
Expert
Message 25 of 34
@Rob364
Yes mate all working fine on my mobile too. 🙂
Carlusha
Recognised Expert
Message 26 of 34
@Carlusha  What is you're normal viewing percentage and do you have to zoom in to 150% or more to see the menus the same.?
Sorry, had been visiting family.
No, I have mine set to 75% as I am using a 43" TV as a monitor and it works perfectly. Only when I zoom to 110% does the category menu disappear but as shown above, those three bars to the left of "Community" reveal the categories.
Rob364
Message 27 of 34
That is the current stable version of EDGE(HTML). EDGE(Chromium) started on ver 79 .
gg30340
Message 28 of 34
Is your monitor replicating your laptop screen or do you have it set as your main monitor with the resolution set correctly and the laptop monitor turned off.
busterboy1
Expert
Message 29 of 34
Have it set as my main monitor. Both Laptop and monitor replicate the same picture.
It's not a big issue as I don't post much but I know if I want to find or start a post I can zoom in and find the index now.
Not practical but doable. 🙂
gg30340
Message 30 of 34
Try turning the laptop monitor off and set the laptops settings to the correct resolution for the monitor.
