busterboy1
Expert
Message 31 of 34
Re: How the heck do you view the forum index???
Already tried that, just the same.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
gg30340
Message 32 of 34
I have just re-read the thread.
Are you complaining because you don't see the three bars?
If that is the case, as has already been pointed out, your screen shot that you posted shows that you are seeing all the forum board options across your screen. That is normal and is how it should be if your screen is large enough.
You would only see the three bars if you screen could not fit all the options across the screen such as when you view it on your mobile.
The three bars contains exactly the same options as is seen across the screen.
busterboy1
Expert
Message 33 of 34
Never mind I've sorted it.
You have to click "Post a question" from BT Community and then get to select.
Rob364
Message 34 of 34
Or use the headings
Click on "Fibre Broadband" and then click on "Post a Question".
