Message 1 of 2
Netflix Scam
I've just had a message purportedly from Netflix asking me to update my payment details.  Ha ha!!
If you get it or something similar just watch out for the link: Netflixplayer(dot)com - Edited
It says you'll be cut off if you don't update but we all know (or should know) better than that.
RIC9380
1 REPLY 1
Message 2 of 2
Re: Netflix Scam
Hi @RIC9380
Thank you for highlighting this.
You're right, this is 100% a scam.  Thanks for being vigilant as you can't be too careful these days.  I had to change the link a little, just so it wasn't clickable as we can't have that link on the site as I'm sure you can appreciate.
It still reads the same and leaving it like that will definitely make other members and visitors aware that this is a scam.
Thanks again,
Robbie
