Message 1 of 65
Private message which is spam
Good Morning
I am not sure if this is the correct board.
I have received a private message from another Community member that is spam. How do I report this as I believe it is against the rules. I expect this person has sent a similar message to other members and personally feel they should be removed from the Community.
Regards
Molly4
64 REPLIES 64
Message 2 of 65
Re: Private message which is spam
Me too...
Message 3 of 65
This the Netflix thing from icequeennl? Me too in that case
Message 4 of 65
Hi Everyone,
I'm really sorry you've received these messages, please don't respond to or click on any of the links that you have been sent as I can confirm they are spam. Please be assured that I am taking the appropriate action against the profiles responsible for these messages and would recommend that you delete any suspicious message you may have received. Many thanks for highlighting this.
Message 5 of 65
Just noticed I had one in November from similar from a RedVines too.
Message 6 of 65
I received a similar message this morning part of which said: "Subject
Blink and it is gone! The best luxury reward offer for you! Here is your chance! Get bonuses now! "
From
Pistachiol
Several suspicious links invited me to click.
Message has been reported then deleted.
Message 7 of 65
Thank you for your reply. My message came from Slayerlz
Message 8 of 65
I had the exact same message..suspected it was spam . But came on here to double check first.
Is nothing sacred anymore !!,,.
Message 9 of 65
I also received this but it was from Avocadosl
Needless to say, it was deleted without opening
Message 10 of 65
I received one this morning from Sierralz.
