Do you mean
Newbie
0
BT wifi & BT Wifi with Fon connection issue
[ Edited ]
in the last 5 days I've had  issues connecting to BT Wifi and BT Wifi with Fon. I'm connecting using an iPhone and iPad so when I use the BT Wifi app for logging in it constantly says check details (which are correct) and then it will connect but then log off and won't connect for ages. It will sometimes connect one device but not the other.
When I try connect using the browser page I get a message ' maximum number of sessions reached'.
Has anyone any idea what causes this, what it means and a possible solution?
ps I tried email BT but they don't seem to care as i've not received a reply,  thanks BT
Community Manager
0
Re: BT wifi & BT Wifi with Fon connection issue
Hi Gioabb,
Welcome to the forum.
Can I just check, is this problem happening with several hotspots or just the one?
Stephanie
Stephanie
BTCare Community Manager
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted Solution’.
Our second newsletter is out now, let us know what you think!
