Do you mean
Newbie
0
Accepted Solution
How to change password for BtOpenZone?
Hi,
Does anyone know how to change password for BtOpenZone? I have tried the following link and it is not working with me....
http://www.btinternet.com/new/content/mybti
Last time I have to ring BT to change the password, but I want to do via some control panel.
Kam
Re: How to change password for BtOpenZone?
If you're a BT Total Broadband customer and you want to change the password, you can go to btyahoo.com, log in there and change your password. The primary email account and the FON/OZ logins are linked. if you change your email password, your FON/OZ password will also change.
if you're an Openzone only customer, you can log into your control panel on the main page and change your password there.
ISP
0
All you need to do is change your primary email addresses password. H_Dawg gave ya some info there but if you can't remember your password just go to http://www.btinternet.com and before trying to sign in click on 'Forgot password' to go through and reset your password to a better one more suited to yourself. Hope this helps.
