Do you mean
0
Unable to connect to Fon when signal strength is low
Hi. I am new and this is my first post, so please be gentle with me.
I signed up to BT so that I could make use of the mobile WiFi from Fon & Openzone while away in my motorhome. If I get a realy strong signal I have no trouble using the service, however, if I am only showing a signal strength of say 50% I cannot sign up to use the service. Although I am quite happy to put up with a slow connection, I do not have that choice as I cannot get to the log-in page to sign in.
Am I doing something wrong or is there something I can do when this happens?
Geoff
0
Re: Unable to connect to Fon when signal strength is low
you need a reasonably strong signal to connect
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
Distinguished Guru
Not always the case John. A weak signal that is stable can and does work. I feel that the OP may in inside their motorhome (aluminium:smileysad:) which would affect the signal.....
Geoff
Hi Geoff and welcome
It should work at 50%:smileyindifferent:. Are you using a laptop with a built in wifi card or a plug in USB wifi adapter?
Via a built in card - If the signal drops have you tried sitting near a window or an open door to rule out your motorhome itself from degrading the signal.
USB adapter - Have you tried using a USB extension lead(s) that you can fix the adapter in a window to maximise the signal strength.
Clearly in both cases you would need to be facing the direction of the signal.
-+-No longer a forum member-+-
0
Hi DS and thanks for your input.
The answer to all your questions is 'Yes'
I do not necessarily demand a signal inside the motorhome, I quite often move around outside to maximise my chances. By the way I use an Alpha AWUS036NHR Wifi adaptor with either their omni-directional antenna or their own directional 7db panel antenna.
I have thought about getting one of the very high gain omni antennas that are around, but they are a lot of money if they do not work too well.
As I said before, if I get a strong signal I am signed in almost immediately, but with a weaker signal I just can't force the laptop to open the BT log-in page, even though I would be happy to run at a much slower speed.
Geoff
Distinguished Guru
Hi Geoff
I would say that the omni directional antenna would be better when moving around outside, other may have their own thoughts.....
A quick google does say that your wifi adapter has a download date of 21/10/12, which could mean that there has been an update. I did also find this page, if it helps - http://www.alfa.com.tw/in/front/bin/ptlist.phtml?Category=105397
Having an up to date driver is always a good idea:smileywink:
0
Thanks DS
I missed that sotware update!!! However I am struggling to install it as the video on the web page is impossible to see clearly???
I will persist in this but it will be difficult without the instructions (I am not too clever with such things)
Geoff
Distinguished Guru
0
Not sure if this would help, but there are several (poor quality:smileysad:) videos on Youtube from the supplier, this one looks to be the clearest of them all - http://www.youtube.com/watch?v=h7j6eMlm-qA&feature=BFa&list=ULsSwygZzUfas
0
Thanks again DS
Much better quality video than the one on Alfa web site.
Having updated driver I will now need to try the Wifi again, fingers crossed for better results.
Geoff
Distinguished Guru
0
Hopefully it will improve.
Let us know how you get on.
