DaveBroadband
Message 11 of 55
Re: 0.5Mb connection speed at weekends. poor speed.
Thanks for your help, yes I have been having problems with media (mobile phones) not working well over the wifi connection, but as mentioned in the OP, The internet down load speed was only 0.5Mb at best over the weekend. I purchased a film and had to watch it by restarting the film several times, fast forwarding to where it had previously stopped.
I will be monitoring the speed daily, but I'm sure it will drop out again, wheather that is due to congession or adverse weather is yet to be seen.
thanks.
DaveBroadband
Message 12 of 55
So far so good.
Wednesdays performance.
DaveBroadband
Message 13 of 55
The internet speed drop so slow that load a new page was painfully slow. Would this be down to congession?
The router has not been powered off.
DaveBroadband
Message 14 of 55
1/2 hour later 17:17 hrs. speed has increased slightly. Not a happy camper.
john46
Message 15 of 55
yes it does look like congestion a matter of waiting while BT Wholesale increase capacity they will be aware of the problem but please keep running the speedtest day and night as they are logged on BT Wholesales servers
NeilO
Moderator
Moderator
Message 16 of 55
@DaveBroadband I'm sorry about the issues with your broadband at peak times, it is likely to be congestion but it's best if this is reported to BT Wholesale to make sure it gets sorted. We'll be happy to help with this if you send over your details using the 'contact the mods' link in my forum profile. You can find the link by clicking on my username .
Neil
DaveBroadband
Message 17 of 55
Early today Thursday 14/07 @ 08:30
DaveBroadband
Message 18 of 55
imjolly
Message 19 of 55
the 2 results are almost identical so why one with tick and other with cross?
DaveBroadband
Message 20 of 55
