HHGTTG
Expert
Message 1 of 3
0845 numbers for dial-up.
I now have Unlimited Anytime phone calls giving also 0845 and 0870 numbers (FUP). But how does BT distinguish 0845 numbers that some ISPs use to give PAYG dial-up from the othe ones for which we're not charged.
2 REPLIES 2
hamish72
Recognised Expert
Message 2 of 3
Re: 0845 numbers for dial-up.
The dial up I use and have used are all 0844  but bI would guess if there are 0845 then its just a data base look up unless the 0845 are all issued in the same group
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
MrP
Message 3 of 3
The old PlusNet dial-up was an 0845 number:
http://www.plus.net/support/dial-up/setup/connection_guide.shtml#4
