CBundy
Message 1 of 5
0901
Hi
My wife wants to vote on BIG BROTHER using the 0901 number but we cant get through any ideas please
TIA
Clive
4 REPLIES 4
Message 2 of 5
Re: 0901
Who you get your phone service from?
CBundy
Message 3 of 5
Re: 0901 -- for the attention of Keith
Hi Keith
My service is BT BROADBAND
I've checked around and can't find a reason (there is probably one right under my nose)
Is there a block on these 0901
Haven't come across the problem before
Thanks for your consideration
Respects
Clive
Message 4 of 5
Re: 0901
BT apply a bar to certain premium rate number groups to prevent people running up large bills.  You could ask them to remove it.
Usually its only put on by request.
Do you pay BT for your phone calls?
I guess you get a message saying that you cannot call these number from this line, or something similar.
Distinguished Guru
Message 5 of 5
@CBundy wrote:
Hi Keith
Respects
Clive
Hi. Welcome to the forums.
Do you have any form of call barring option on your phone line ? There are different types, and sometimes based on exchange type I believe. I think that International and premium rate barring is done on some exchanges, but are separate for others.
Tp be frank, you should be aware that you have call barring options - and you may have a PIN you can use to enable access to dial a premium rate number on an individual call basis.
