Mark_W
Message 1 of 4
10 day training - does it matter if I don't use a HomeHub?
Hi,
I've just had my ADSL service installed (the fibre cabinet near me is full unfortunately).   Instead of using the BT Homehub I am instead using an Asus DSL-AC88U.
My question is - will my use of a non-BT-modem/router in any way affect the 10 day learning process/DLM, or does it not matter?   Or to put it another way, will the DLM process work better if I connect up my Homehub rather than the Asus?
Thanks in advance for any advice.
3 REPLIES 3
XRaySpeX
Recognised Expert
Message 2 of 4
Re: 10 day training - does it matter if I don't use a HomeHub?
It won't affect it. Many users on other ISPs use other routers perfectly well. It's the same BB connection & DLM, managed by BT Wholesale, whether BT's your ISP or not.
The Asus DSL-AC88U is a superior router. Good Internetting with it :).
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Mark_W
Message 3 of 4
Thanks for the super quick reply. That's great. I couldn't see quite how it might make a difference but I had a nagging thought in the back of my head that wouldn't go away!
XRaySpeX
Recognised Expert
Message 4 of 4
Thanks! You're welcome :)! Glad I could be of assistance.
