pippincp
Sage
Message 11 of 13
Re: 100 Ping higher than Normal on Dota 2 Servers (Valve Servers)
You could always email the admin of tinet.net and ask him what the problem is as that seems to be where the problem starts. (LOL community were reporting same problem with them in April).
admin-email: sven.englehardt@tinet.net
I've removed the email masking for you.
flamey
Message 12 of 13
No issues for myself currently, looks like a VP or node issue between hop 13-14 perhaps only during peak times.
Tracing route to 146.66.154.88 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 5 ms 5 ms 5 ms 217.32.146.71
3 5 ms 5 ms 5 ms 217.32.146.110
4 6 ms 6 ms 6 ms 213.120.156.42
5 6 ms 6 ms 6 ms 217.41.168.57
6 6 ms 6 ms 5 ms 217.41.168.107
7 6 ms 6 ms 5 ms 109.159.249.108
8 6 ms 7 ms 8 ms core1-te0-0-0-7.faraday.ukcore.bt.net [109.159.249.5]
9 18 ms 11 ms 11 ms 213.131.193.6
10 7 ms 6 ms 6 ms core1-pos9-1.telehouse.ukcore.bt.net [194.74.65.114]
11 7 ms 6 ms 6 ms t2as1-tge1-4.uk-lon1.eu.bt.net [166.49.211.141]
12 6 ms 6 ms 6 ms 166-49-211-38.eu.bt.net [166.49.211.38]
13 19 ms 19 ms 19 ms xe-1-0-1.fra21.ip4.tinet.net [89.149.185.194]
14 25 ms 25 ms 24 ms valve-gw.ip4.tinet.net [77.67.74.170]
Seanb2uk
Message 13 of 13
Eventually as the night goes on, and it gets later and further away from peak times ping goes back to what it should be ALL the time.
It's very odd. If its the same again tomorrow night, i'll email tinet. Thanks pippincp
This what I get at 3:30am...yes i'm going to bed now 🙂
Target Name: N/A
         IP: 146.66.153.157
  Date/Time: 17/05/2012 03:27:13
 1    0 ms  [192.168.1.254]
 2   14 ms   [217.32.140.66]
 3   14 ms   [217.32.140.30]
 4   14 ms  [213.120.161.2]
 5   14 ms  [217.32.26.78]
 6   14 ms  [217.32.26.178]
 7   14 ms  acc1-10GigE-0-0-0-4.bm.21cn-ipp.bt.net [109.159.248.66]
 8   33 ms  core1-te0-3-0-3.ealing.ukcore.bt.net [109.159.248.20]
 9   22 ms  transit1-pos1-0-0.telehouse.ukcore.bt.net [62.6.201.82]
10   23 ms  t2as1-tge4-4.uk-lon1.eu.bt.net [166.49.211.145]
11   22 ms  166-49-211-38.eu.bt.net [166.49.211.38]
12   36 ms  xe-1-2-1.fra21.ip4.tinet.net [89.149.187.213]
13   43 ms  valve-gw.ip4.tinet.net [77.67.74.170]
