hi so my hub likes to reset itself every 2 weeks but it reset itself last thursday then stable all week but then it still goes ahead with its 14day reset thing? its so wierd whys it do it? and different Q why is my max data rat coming down is it new peeps joining? my max rate used to be 78 now its 74600 my line syncs at 73900mbps not complaining just wondering.
your max data rate and also your noise margin will fluctuate all day if you watch them as long as your data rate remains the same then nothing to worry about
A gradual reduction in the data rate could be due to crosstalk http://www.increasebroadbandspeed.co.uk/2014/vectoring-crosstalk-crisis
as someone who suffered the 14 days reset I know how annoying it can be but that is all it is as, if like mine, downltime was minimal and conenction returned just as it was before the reset mine stopped all of a sudden having done nothing to try and improve the hh5a so it does stop. I then went on to have 90 days until a power cut ended the run
I solved that by resetting the hub at a time it was convenient to me so the 14 days were at a time I knew would not cause me a problem. It does tend to 'creep' so I had to check when the resets happened and if likely to cause me problem then I just did the process again
as I posted before the resets just stopped and that was before the new firmware update so just as out of the blue it started it stopped
Hi again outy.
Have a look at an unlocked hg612 3b openreach modem and a 3rd party router that works with bt tv .*
The unlocked openreach hg612 3b stops the dreaded bt vlan 301 and ditching the hh5 (both types) gets rid of the TR-069 bug for the 14 day resets.
I use the unlocked modem and a 3rd party and the line in so stable its almost dull 🙂
The only time these days I load up the line connection software is xmas hoildays to keep an eye out for flashing lights affecting the line.
*Asus and Apple seem popluar -
https://community.bt.com/t5/YouView-Boxes/Using-a-3rd-party-router-for-Multicast/td-p/1048582
