Message 11 of 13
Re: 1571 on landline
@gspearson, possibly when the text alert feature was set up for 1571 your landline number was entered instead of a mobile number. When the text is sent to your landline to say you have a new message it may then be converting the text to speech.  Did you call the number I posted to see if you can disable it?
Message 12 of 13
@NeilO Just tried that.  It offered to setup a link to my mobile and asked me to set a PIN (after confirming my landline number).  Clearly, as I expected, I don't have a link to a mobile nor a PIN - I would not have set up such an arrangement as I don't use my mobile for calls and it doesn't make any sounds.
I'll regard it as an unwanted benefit of the recent upgrade and ignore calls from my own landline number.
Message 13 of 13
@NeilO   Apologies, I've just searched my emails and found one in September from BT giving me a PIN but without saying what it was for - email was in the deleted folder.
