Hi @sido,
I've sent you a Private Message with the details for how you can contact the Moderation team.
Thanks,
Paddy
Hi Paddy
Please can you send me details of how to get the firmware update as I cannot print unless I turn off the 5GHZ.
Cheers
John
Thanks Paddy
Replied to PM. Hopefully the FW update will remedy this because having to use only 2.4GHZ sucks
Hi @PaddyB
I've had the firmware update now, and my devices all seem to be able to communicate across both the 2.4 and 5 bands. However, the only device that doesn't is my HP printer. The printer is only 4 months old, so I doubt it'll be the printer?
To print without resulting to a wired connection or emailing to the printer direct, I still need to switch one band off.
@B3NNYB0Y just to let you know, I had the firmware update on my Smart Hub 2 and now everything works as expected.
Paddy,
Would it be possible to arrange the latest firmware upgrade for my router?
