Message 151 of 984
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
Hi NeilO
I am also having problems connecting wifi to all my devices lately so frustrating.
Roshys701
Message 152 of 984
Hi @Roshys701  and @chappsy  sorry that you are having this issue. I've sent you both a Private Message with details on how to contact the Mod team and we'll be happy to look into the problems you have further for you.
cheers
John
Message 153 of 984
Same problem with my wireless HP printer not printing from our family iPads since I had the update on 4th April when BT were trying to resolve the problem on my Vodafone Sure signal failure.
if I do a network settings reset on the iPads I can print once, then it fails to connect on subsequent tries.
I can’t find a way to tell the iPad to use 2.4Ghz wifi on iOS 14 so hoping for a prompt fix to the update from BT soon.
Nigel
Message 154 of 984
Countax
You could always just switch off the 5GHz band in router settings, not ideal but until new update.
Message 155 of 984
Hi @lifeonmars
Thanks. This is what I've done since late 2020 but I'm not so sure the update from 17th April addresses this issue.
Message 156 of 984
B3NNYB0Y
The firmware v0.26.03.01286-BT is the issue at the moment.
Message 157 of 984
Has anybody tried Mode 2? I am reluctant to swap back to the SH2 until there is a fix or a work-a-round apart from using an old HH6.
Message 158 of 984
I tried Mode 2.  Didn't help.  Also tried disabling IPv6 just in case.  Same, no help.  I can sometimes briefly connect after a reboot, as my iPad sometimes starts with the 2.4GHz network, then quickly finds the 5GHz and printers/speakers etc are stuffed.
I requested BT to send me a SmartHub1 and am about to install it as a temporary fix.
Message 159 of 984
Hi @AlanMP   I dusted off an old SmartHub1 (HH6) and immediately got a 100% solid connection on all devices. I should say that I changed the SSID and password to match the SH2 but I did split the bands.
Message 160 of 984
Rather annoyingly I can’t connect to my SkyHD box from my iPad on the same network anymore and watch sky-go F1 practice as the sky box is on 2.4Ghz and the iPad on 5Ghz.
Nigel
