Message 901 of 984
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
Thank you  @DavidM .
I have received your message and replied with a little more information which I will repeat here:
I spoke (in Chat) to a person in BT Support this morning about this issue and he said he would try to push the Firmware Update to me.  However he tried a few times but he said that he could not see my SH2 connected at all online.  We were both puzzled as I was actually using it to 'Chat'.  The outcome was that he decided it best to send me a replacement SH2.  I will see how I get on with it
I will update here with progress on this.
Message 902 of 984
Thanks for getting back to me @EdLander .
Please do let me know how you get on with the replacement hub. If that doesn't work out we'll pick up from there.
Cheers
David
Message 903 of 984
Thanks. Restart indeed sorted the printer and SkyQ box issues. Sonos remains hit and miss, but I guess I have to live with that.
Message 904 of 984
@DavidH54 if you can plug one of your Sonos speakers into the hub or BT Disk with a Lan cable. This will resolve all the Sonos connectivity issues.
Message 905 of 984
@DavidH54  What @craftycooky ssys is nearly correct about Sonos speakers. Unfortunately if you have a Sonos move speaker, as this is WiFi only, that may continue to have issues until you get the SH2 firmware update.
Message 906 of 984
@DavidH54 The move will connect to sonosnet if there is another Sonos speaker plugged in with a Lan cable
Message 907 of 984
Thanks for the Sonos advice. However it is a wifi only speaker, so LAN won’t help - and even if could connect, it’s not an easy cable run to the router. I just need to keep restarting the Sonos if it fails to connect to SH2.
Message 908 of 984
@DavidH54  which Sonos speaker is it?
Message 909 of 984
It’s a Sonos One SL.
Message 910 of 984
@DavidH54 the SONOS ONE SL also uses SonosNET. If you’re still using the Sonos S1 app, you can buy a Sonos bridge on eBay and plug that into your router. This will move the speaker ifc the Wi-Fi onto its own dedicated mesh network.
that’s how I initially overcame the SH2 issues. It’s also very stable. The speaker becomes a node in the SonosNET network and if y add another Sonos speaker (apart from the move) it extends the network.
