Message 921 of 984
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
@G8ZIG  What firmware version do you have on the SH2 router?
When you say you can’t use the devices, is that an issue with them not connecting to the dual band WiFi, or a controller not being able to see/control them?
If it’s that they won’t connect to the WiFi, temporarily turn off the 5Ghz band, connect the devices and then turn the 5Ghz band back on. Alternatively leave the 5Ghz band turned off.
if it’s that the controller can’t see the devices, the latest firmware should fix that.
Message 922 of 984
The firmware on the new router is v0.31.00.10253-BT
The switching the 5Ghz side off temporarily allowed me to set up my camera so I am grateful for that information.
Message 923 of 984
I have this problem when trying to install smart devices. I have checked the smartware version that I am running and it is v0.31.00.10253-BT
Please push out the update to me asap.
Jonny
Message 924 of 984
There is no update
Message 925 of 984
@greeneyedbuddhist  What problem and what smart devices?
My SH2 router is running the same firmware with no issues.
I have Echo Dots (3rd gen), Echo Flex, SONOS speakers, Hive hub, Phillips Hue hub, Smart TV, Deebot vacuum, HP Printer all connected with no issues.
Message 926 of 984
Please send me a push firmware update so that my hub can connect to 2.4 and 5ghz
the hub isn’t running the firmware you listed that resolves the problem, although according to the manager both are switched on.
Message 927 of 984
are you running current firmware ending 12274-BT
Message 928 of 984
@imjolly , yes I’m running it. Updated 24-Apr-2022.
Message 929 of 984
v0.33.00.12274-BT
Looks like it should be latest firmware?
I just can’t connect a new smart bulb as it can’t find the 2.4 Ghz.
Message 930 of 984
@trevorflt1wrote:
v0.33.00.12274-BT
Hi @trevorflt1    Are you turning off the 5 GHz band during the connection process? Once the device is connected you can turn the 5 GHz band back on.
