Message 1 of 1
2 SmartHubs: Create subnet
I have two SmartHub 2s. One has the red WAN port. I want to create a secondary isolated subnet. Can I connect primary router's LAN to secondary router's WAN?
I can't seem to change the DHCP settings on the secondary router, it tells me it's invalid. As far as I understand it I need to set the the secondary router's gateway to outside of the primary's DHCP range but within the same subnet (penultimate number). But I also need to change the secondary's DHCP range to be on its own subnet (penultimate number). However the hub only lets me set the gateway IP and DHCP range to be on the same subnet, it says it's invalid if I try
