lee87
Message 1 of 3
2 laptop's disconnecting
each time i have both laptops on at the same time the hub kicks them off and will not reconnect them unless i restart my hub.Is my hub broke? because also if you touch the power cord in the back it restarts the hub
2 REPLIES 2
Message 2 of 3
Re: 2 laptop's disconnecting
Hi you could check that your power lead is fully pushed into the connector on the hub are you connecting by ethernet or wireless????
lee87
Message 3 of 3
it is pushed in properly and everytime i check that thats when it restarts itself. The 2 laptops are connected via wireless
