Shaenei
Message 1 of 6
20mbps drop in speed
When i first got infinity 2 i had a decent connection with 72mbps down, 18-29mbps up. I'm now getting the following speeds
my line should be getting this
Do you think i'm justified is requesting my line profile gets reset?
5 REPLIES 5
john46
Message 2 of 6
Re: 20mbps drop in speed
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
john46
Message 3 of 6
BT cannot reset the DLM that can only be done by an Openreach engineer if a line fault is found
Keith_Beddoe
Message 4 of 6
Shaenei
Message 5 of 6
Here's the info from the tech log, today's restart was the hub6 doing a firmware update
From my understanding that noise margin is a good figure, the dlm just doesn't seem to want to increase even though the connection IMHO is relatively stable
john46
Message 6 of 6
It looks more like cross talk and there is nothing you can about that as it happens as more users are connected to the cabinet
