BuckleZ
Message 1 of 6
217.32.27.182
There is a serious issue with the device at 217.32.27.182 - or there is some sort of congestion happening at peak times.
Any offical word from BT?
5 REPLIES 5
ironman123
Recognised Expert
Message 2 of 6
Re: 217.32.27.182
Looks ok to me trace & ping below.
Tracing route to 217.32.27.182 over a maximum of 30 hops
  1     1 ms     1 ms    <1 ms  x.x.x.x
  2     6 ms     6 ms     5 ms  217.32.145.225
  3     6 ms     6 ms     6 ms  217.32.146.14
  4    10 ms    10 ms     9 ms  213.120.181.86
  5    10 ms    10 ms    10 ms  217.32.25.62
  6    10 ms    10 ms    10 ms  217.32.25.182
  7    14 ms    14 ms    13 ms  217.32.27.182
Trace complete.
C:\Documents and Settings\xxxxxxx>ping 217.32.27.182
Pinging 217.32.27.182 with 32 bytes of data:
Reply from 217.32.27.182: bytes=32 time=14ms TTL=249
Ping statistics for 217.32.27.182:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 14ms, Maximum = 14ms, Average = 14ms
I have not looked it up on who`s/who but if it is a P2P site then it will be subjected to slower speed during peak times and maybe at other times too,as BT class P2P as low piority.
stanloi
Message 3 of 6
Re: 217.32.27.182
only seems to happen at peak times
i'm not doing any P2P, just watching iplayer, playing a bit of xbox and streaming sky on the xbox
http://community.bt.com/t5/BT-Infinity/speed-test-results-right-possible-latency-not-sure/td-p/39456...
http://community.bt.com/t5/BT-Infinity/Appalling-Latency-with-Infinity-in-Oldham/td-p/394453
http://community.bt.com/t5/BT-Infinity/problem-with-infinity/td-p/394437/page/5
this is where i am keeping tracks with it, also have a call logged
ironman123
Recognised Expert
Message 4 of 6
Re: 217.32.27.182
Umm! Are you in Oldham,if so then it could mean that the problem with bad latency in that area [as stated in one of the links you gave] is still not resolved.
Are you only having probs with just the site that I pinged,or is it all sites.?
john46
Message 5 of 6
Re: 217.32.27.182
buckle Z as has been posted before why not contact the forum mods and get them involved they are able to get this sort of problem resolved here is the link http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 72 hours
They are a UK based BT specialist team who have a good record at getting problems solved
Paul1360
Expert
Message 6 of 6
Re: 217.32.27.182
This IP address is BT in England according to this:-
http://www.ip-adress.com/whois/217.32.27.182
