DHS_Jon
Message 1 of 3
21CN Network upgrade
Hi,
I have received the email from BT saying that our area has upgraded to 21CN. However, I see no improvement in my BB speed - it appears that I'm still on the 8meg BB (BT quote 17 meg on ADSL2+)
Router suggests that I've not been upgraded, based on stats (modulation) and reading other posts (see below).
Is this normal? Do I need to start a new contract? I thought BT always offered the fastest possible speed!
Thanks in advance
Jon
Homehub info:
Broadband connection details:
Downstream8,064 Kbps
Upstream448 Kbps
Uptime:8 days, 2:44:39
Modulation:G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:448 / 8,064
Data Transferred (Sent/Received) [MB/GB]:251.96 / 4.03
Output Power (Up/Down) [dBm]:9.5 / 19.5
Line Attenuation (Up/Down) [dB]:8.5 / 24.0
SN Margin (Up/Down) [dB]:28.0 / 9.0
Vendor ID (Local/Remote):TMMB / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):0 / 16,458
CRC Errors (Up/Down):0 / 761
HEC Errors (Up/Down):0 / 615
Line Profile:Interleaved
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: 21CN Network upgrade
you are as you said still on adslmax.
if you have read some of the forum posts similar to your own you will have read that the upgrade is done on a phased approach of some weeks but if you wait then there is no new contract required.
however it is possible to get upgraded quicker but then you need to agree a new contract.
I would also check some of the post using the search facility 'upgrade problems' just so you know the problems than can come with the 21CN upgrade
DHS_Jon
Message 3 of 3
Thanks for the speedy reply. I guess I shall just have to wait then.
I must say, though, that I find it frustrating when the call centre say one thing when, in fact, it is the complete opposite that is the truth.
