kylrod
Message 1 of 7
21cn upgrade
hi iam nearing the end of my 10day stabiliastion period got upgraded a week past thur. was told at the time i upgraded i should achieve around 17mb. i only live 300meters from exchange, there is no cabnet or pole between us.  howver my sync speeds keep dropping every other day. i havent touched my modem once. this is my stats when i was 1st upgraded
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 04:49:43
Downstream23,257 Kbps
Upstream1,219 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeInterleaved
Noise margin (Down/Up)4.8 dB / 6.7 dB
Line attenuation (Down/Up)14.4 dB / 6.4 dB
Output power (Down/Up)34.6 dBm / 1.8 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)4537 / 0
HEC Errors (Down/Up)1882 / 0
Error Seconds (Local/Remote)3351 / 0
this is my stats now its **bleep** of a difference.
ADSL line status
Line stateConnected
Connection time1 days, 17:24:03
Downstream14,335 Kbps
Upstream864 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)8.5 dB / 17.8 dB
Line attenuation (Down/Up)13.5 dB / 6.3 dB
Output power (Down/Up)33.9 dBm / 1.3 dBm
FEC Errors (Down/Up)13427 / 0
CRC Errors (Down/Up)771 / 0
HEC Errors (Down/Up)24759 / 0
Error Seconds (Local/Remote)21 / 0
 how can i get it back to what it was, there didnt appear to be any problems with dissconnects or anything
6 REPLIES 6
Message 2 of 7
Re: 21cn upgrade
Hi one thing comes immediately to my attention your noise margin has increased which will reduce your sync speed this is normally caused by disconnections causing resets to the hub providing the hub is left with no restarts the noise margin will drop and the speed will return as the exchange equipment sees the line as stable
kylrod
Message 3 of 7
Re: 21cn upgrade
hi thanks for the reply, i havent touched my hub at all jst left it to do its own thing. why would it dissconnect if it was working ok?  will it eventually go back to the way it was when it was 1st upgraded?
Message 4 of 7
Re: 21cn upgrade
the disconnections have been caused by line noise causing instability on your line left alone it will go back to normal just keep an eye on your hub up time if it keeps dropping then you will need to get the help of the board mods to sort out your line you can contact them at http://bt.custhelp.com/app/contact_email/c/4951
but leave the line for 5 days before contacting them to ensure it is stable then ask them to resets your noise margin to its 6db default
kylrod
Message 5 of 7
Re: 21cn upgrade
has been connected for jst over 2days now without disconnects but no sighn of the noise margin dropping how longdoes it take normally?
Message 6 of 7
Re: 21cn upgrade
as i said in my earlier post if after 5 days it has not dropped then contact the board mods and ask them to reset your noise margin this is the mail address http://bt.custhelp.com/app/contact_email/c/4951
IceZaroth
Message 7 of 7
Re: 21cn upgrade
Sorry to jump in on this post but the Exchange goes through a training period to find the most stable connection possible, once its tryied a few different varibles your line will sort its self out just takes time.
IceZaroth
BT Community Helper
