SeanD
Community Manager
Community Manager
Message 51 of 63
Re: 22.17.0 software update
Hi Everyone,
I am very sorry for the delay in you receiving this software update.  I have good news.
This particular update will be rolled out to all BT YouView customers tomorrow night, Thursday 18/02/2016.  By Friday you should all have it Smiley Happy
Cheers
Sean
Old_Welsh_dragon
Message 52 of 63
speedtrip
Expert
Message 53 of 63
love to know what the delay was all about ..... 6 weeks to the day since announced, holds the all-time record I bet ....
ney
Expert
Message 54 of 63
Finally got the new software update a short time ago.
Darren
HaggisUK
Message 55 of 63
Just received the update. I have the RF loop through turned on......am I right in thinking that when the box goes into deep sleep the RF option no longer works?
Cheers.
olgitnorm
Message 56 of 63
Think it depends which box you have, I have the old model and it works fine in deep sleep mode but believe it is different with the newer boxes
gomezz
Recognised Expert
Message 57 of 63
Got it today. Agree with other poster who says there should be more options for setting the start time for the Smart Eco mode. Even perhaps setting it change an hour before the first timer set for that day / evening and changing back an hour after being turned off?  That would fit in more with the way I had my old Toppy / MyStuff set up which remains in many respects the gold standard for a PVR UI.
skappy70
Recognised Expert
Message 58 of 63
Yes, on the G4 model the RF out stops working when in deep sleep but the G3 still works.
mikemoyes1987
Message 59 of 63
got it yesterday once I got home from work, much quicker boot up now from standby
HaggisUK
Message 60 of 63
Thanks for the replies. I can now verify the RF setting dosen't work while in deep sleep.
