Dave_J
Message 1 of 4
24 & 5GHZ query
Help please.
I have a WD device which is very slow with my BT5 HUB connected by cable as a network.
In my PC network map the default is 2.4GHZ connection. ie with cable connection I see on my PC BT HuB5-***
If connected without cable using  wiFi it is much faster and is using 5GHZ. on PC network map i see BT Hub5-***GHZ
Can I make the 5GHZ frequency to be used for cable network operation?
Thanks for looking
3 REPLIES 3
licquorice
Message 2 of 4
Re: 24 & 5GHZ query
2.4Ghz and 5Ghz refer purely to wireless operation. If you connect by Ethernet, it has no meaning.
Dave_J
Message 3 of 4
Re: 24 & 5GHZ query
Thanka for replying. I am trying to see why image transfers from PC to WD are at about 1.4MB/s using ethernet yet 12-14 MB/s by wireless connection. PC has Gigabit card and cable being used directly from hub is the new one which came with the kit. Tried ethernet mains plugs, same result.
Obviously not a BT Hub problem but seemed a way to go having spent much time trying to find something amiss with the WDMyCloud.
Message 4 of 4
Re: 24 & 5GHZ query
Your ethernet cable is bad
