Jamesvolvo
Message 1 of 28
2nd home hub 5, Infinity still keeps disconnecting frequently
Hello all
(update on earlier posts)
I had Infinity 1 installed last week. Frequent line disconnections and wifi dropouts. BT sent me a new HH5.
WiFi now OK I think - I switched off auto channel selection and I _think_ that helped.
However - I am still getting loads of line drops - several per day and sometimes it only stays up for an hour.
Please can someone look at the diag print and logs and tell me what I should do next? I'm loath to contact BT again as I suspect they'll just send another HH5. I'm plugged into the master socket, all internal wiring disconnected.
The longest the line's been up for is about 24 hours, and when it's up it works fine i.e. I'm measuring about 36Mbit/s download speed.
Ideas gratefully received, thanks
1. Product name:
BT Home Hub
2. Serial number:
+068543+NQ40139347
3. Firmware version:
Software version 4.7.5.1.83.8.204 (Type A) Last updated Unknown
4. Board version:
BT Hub 5A
5. DSL uptime:
0 days, 03:06:52
6. Data rate:
8492 / 39997
7. Maximum data rate:
28607 / 84043
8. Noise margin:
19.9 / 12.9
9. Line attenuation:
18.4 / 16.6
10. Signal attenuation:
18.2 / 16.6
11. Data sent/received:
1.6 GB / 18.9 GB
12. Broadband username:
bthomehub@btbroadband.com
13. BT Wi-fi:
14. 2.4 GHz Wireless network/SSID:
Victory
15. 2.4 GHz Wireless connections:
Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:
WPA2
17. 2.4 GHz Wireless channel:
11
18. 5 GHz Wireless network/SSID:
Victory
19. 5 GHz Wireless connections:
Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:
WPA2
21. 5 GHz Wireless channel:
48
22. Firewall:
Default
23. MAC Address:
34:8a:ae:89:b8:0c
24. Modulation:
G.993.2 Annex B
25. Software variant:
AA
26. Boot loader:
1.0.0
27 REPLIES 27
Jamesvolvo
Message 2 of 28
Re: 2nd home hub 5, Infinity still keeps disconnecting frequently
04:10:52, 28 Apr.
(236591.820000) WAN operating mode is VDSL
04:10:52, 28 Apr.
(236591.820000) Last WAN operating mode was VDSL
04:10:50, 28 Apr.
(236590.000000) PPP IPCP Receive Configuration ACK
04:10:50, 28 Apr.
(236589.970000) PPP IPCP Send Configuration Request
04:10:50, 28 Apr.
(236589.970000) PPP IPCP Receive Configuration NAK
04:10:50, 28 Apr.
(236589.970000) PPP IPCP Send Configuration ACK
04:10:50, 28 Apr.
(236589.970000) PPP IPCP Receive Configuration Request
04:10:50, 28 Apr.
(236589.940000) PPP IPCP Send Configuration Request
04:10:48, 28 Apr.
(236588.280000) PPPoE is up -​ Down Rate=39997000Kbps, Up Rate=8492000Kbps; SNR Margin Down=12.8dB, Up=19.9dB
04:10:48, 28 Apr.
(236588.270000) CHAP authentication successful
04:10:48, 28 Apr.
(236588.010000) CHAP Receive Challenge
04:10:48, 28 Apr.
(236588.010000) Starting CHAP authentication with peer
04:10:48, 28 Apr.
(236588.010000) PPP LCP Receive Configuration ACK
04:10:48, 28 Apr.
(236587.980000) PPP LCP Send Configuration Request
04:10:48, 28 Apr.
(236587.980000) PPP LCP Receive Configuration Reject
04:10:48, 28 Apr.
(236587.980000) PPP LCP Send Configuration ACK
04:10:48, 28 Apr.
(236587.980000) PPP LCP Receive Configuration Request
04:10:48, 28 Apr.
(236587.960000) PPP LCP Send Configuration Request
04:09:55, 28 Apr.
(236534.890000) PTM over DSL is up
04:09:19, 28 Apr.
(236499.580000) PTM over DSL is down after 163 minutes uptime
04:09:19, 28 Apr.
(236499.580000) PPPoE is down after 162 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
04:09:14, 28 Apr.
(236494.090000) PPP LCP Send Termination Request [User request]
01:26:29, 28 Apr.
(226729.480000) WAN operating mode is VDSL
01:26:29, 28 Apr.
(226729.480000) Last WAN operating mode was VDSL
01:26:27, 28 Apr.
(226727.670000) PPP IPCP Receive Configuration ACK
01:26:27, 28 Apr.
(226727.640000) PPP IPCP Send Configuration Request
01:26:27, 28 Apr.
(226727.630000) PPP IPCP Receive Configuration NAK
01:26:27, 28 Apr.
(226727.630000) PPP IPCP Send Configuration ACK
01:26:27, 28 Apr.
(226727.630000) PPP IPCP Receive Configuration Request
01:26:27, 28 Apr.
(226727.570000) PPP IPCP Send Configuration Request
01:26:26, 28 Apr.
(226725.910000) PPPoE is up -​ Down Rate=34993000Kbps, Up Rate=7200000Kbps; SNR Margin Down=15.0dB, Up=21.0dB
01:26:26, 28 Apr.
(226725.810000) CHAP authentication successful
01:26:26, 28 Apr.
(226725.690000) CHAP Receive Challenge
01:26:26, 28 Apr.
(226725.690000) Starting CHAP authentication with peer
01:26:26, 28 Apr.
(226725.690000) PPP LCP Receive Configuration ACK
01:26:25, 28 Apr.
(226725.570000) PPP LCP Send Configuration Request
01:26:25, 28 Apr.
(226725.570000) PPP LCP Receive Configuration Reject
01:26:25, 28 Apr.
(226725.570000) PPP LCP Send Configuration ACK
01:26:25, 28 Apr.
(226725.570000) PPP LCP Receive Configuration Request
01:26:25, 28 Apr.
(226725.450000) PPP LCP Send Configuration Request
01:25:32, 28 Apr.
(226672.000000) PTM over DSL is up
01:24:47, 28 Apr.
(226627.400000) PTM over DSL is down after 0 minutes uptime
01:24:46, 28 Apr.
(226625.850000) PPPoE is down after 0 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
01:24:44, 28 Apr.
(226624.410000) PPP LCP Send Termination Request [User request]
01:24:44, 28 Apr.
(226624.360000) PPP IPCP Send Configuration Request
01:24:43, 28 Apr.
(226622.730000) PPPoE is up -​ Down Rate=34993000Kbps, Up Rate=7200000Kbps; SNR Margin Down=15.9dB, Up=22.0dB
01:24:43, 28 Apr.
(226622.710000) CHAP authentication successful
01:24:42, 28 Apr.
(226622.600000) CHAP Receive Challenge
01:24:42, 28 Apr.
(226622.600000) Starting CHAP authentication with peer
01:24:42, 28 Apr.
(226622.600000) PPP LCP Receive Configuration ACK
01:24:42, 28 Apr.
(226622.570000) PPP LCP Send Configuration Request
01:24:42, 28 Apr.
(226622.570000) PPP LCP Receive Configuration Reject
01:24:42, 28 Apr.
(226622.570000) PPP LCP Send Configuration ACK
01:24:42, 28 Apr.
(226622.570000) PPP LCP Receive Configuration Request
01:24:42, 28 Apr.
(226622.550000) PPP LCP Send Configuration Request
01:23:49, 28 Apr.
(226569.150000) PTM over DSL is up
01:23:04, 28 Apr.
(226524.560000) PTM over DSL is down after 432 minutes uptime
01:23:04, 28 Apr.
(226524.550000) PPPoE is down after 431 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
01:22:59, 28 Apr.
(226519.090000) PPP LCP Send Termination Request [User request]
18:11:40, 27 Apr.
(200640.160000) WAN operating mode is VDSL
18:11:40, 27 Apr.
(200640.160000) Last WAN operating mode was VDSL
18:11:38, 27 Apr.
(200638.360000) PPP IPCP Receive Configuration ACK
18:11:38, 27 Apr.
(200638.330000) PPP IPCP Send Configuration Request
18:11:38, 27 Apr.
(200638.330000) PPP IPCP Receive Configuration NAK
18:11:38, 27 Apr.
(200638.330000) PPP IPCP Send Configuration ACK
18:11:38, 27 Apr.
(200638.330000) PPP IPCP Receive Configuration Request
18:11:38, 27 Apr.
(200638.300000) PPP IPCP Send Configuration Request
18:11:36, 27 Apr.
(200636.680000) PPPoE is up -​ Down Rate=34993000Kbps, Up Rate=7200000Kbps; SNR Margin Down=15.2dB, Up=20.9dB
18:11:36, 27 Apr.
(200636.670000) CHAP authentication successful
18:11:36, 27 Apr.
(200636.390000) CHAP Receive Challenge
18:11:36, 27 Apr.
(200636.390000) Starting CHAP authentication with peer
18:11:36, 27 Apr.
(200636.390000) PPP LCP Receive Configuration ACK
18:11:36, 27 Apr.
(200636.360000) PPP LCP Send Configuration Request
18:11:36, 27 Apr.
(200636.360000) PPP LCP Receive Configuration Reject
18:11:36, 27 Apr.
(200636.360000) PPP LCP Send Configuration ACK
18:11:36, 27 Apr.
(200636.360000) PPP LCP Receive Configuration Request
18:11:36, 27 Apr.
(200636.340000) PPP LCP Send Configuration Request
18:10:43, 27 Apr.
(200583.140000) PTM over DSL is up
18:09:59, 27 Apr.
(200539.180000) PTM over DSL is down after 14 minutes uptime
18:09:59, 27 Apr.
(200539.180000) PPPoE is down after 14 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
18:09:53, 27 Apr.
(200533.210000) PPP LCP Send Termination Request [User request]
17:55:54, 27 Apr.
(199694.300000) WAN operating mode is VDSL
17:55:54, 27 Apr.
(199694.300000) Last WAN operating mode was VDSL
17:55:52, 27 Apr.
(199692.530000) PPP IPCP Receive Configuration ACK
17:55:52, 27 Apr.
(199692.500000) PPP IPCP Send Configuration Request
17:55:52, 27 Apr.
(199692.490000) PPP IPCP Receive Configuration NAK
17:55:52, 27 Apr.
(199692.490000) PPP IPCP Send Configuration ACK
17:55:52, 27 Apr.
(199692.490000) PPP IPCP Receive Configuration Request
17:55:52, 27 Apr.
(199692.470000) PPP IPCP Send Configuration Request
17:55:51, 27 Apr.
(199690.870000) PPPoE is up -​ Down Rate=34997000Kbps, Up Rate=7199000Kbps; SNR Margin Down=16.2dB, Up=22.5dB
17:55:51, 27 Apr.
(199690.850000) CHAP authentication successful
17:55:51, 27 Apr.
(199690.770000) CHAP Receive Challenge
17:55:51, 27 Apr.
(199690.770000) Starting CHAP authentication with peer
17:55:51, 27 Apr.
(199690.770000) PPP LCP Receive Configuration ACK
17:55:51, 27 Apr.
(199690.740000) PPP LCP Send Configuration Request
17:55:51, 27 Apr.
(199690.740000) PPP LCP Receive Configuration Reject
17:55:51, 27 Apr.
(199690.740000) PPP LCP Send Configuration ACK
17:55:51, 27 Apr.
(199690.740000) PPP LCP Receive Configuration Request
17:55:51, 27 Apr.
(199690.720000) PPP LCP Send Configuration Request
17:54:57, 27 Apr.
(199637.460000) PTM over DSL is up
http://192.168.1.254/images/empty.gif
17:54:06, 27 Apr.
(199586.480000) PTM over DSL is down after 24 minutes uptime
17:54:06, 27 Apr.
(199586.470000) PPPoE is down after 23 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
17:54:01, 27 Apr.
(199581.090000) PPP LCP Send Termination Request [User request]
17:30:31, 27 Apr.
(198170.710000) WAN operating mode is VDSL
17:30:31, 27 Apr.
(198170.710000) Last WAN operating mode was VDSL
17:30:29, 27 Apr.
(198168.900000) PPP IPCP Receive Configuration ACK
17:30:29, 27 Apr.
(198168.880000) PPP IPCP Send Configuration Request
17:30:29, 27 Apr.
(198168.870000) PPP IPCP Receive Configuration NAK
17:30:29, 27 Apr.
(198168.870000) PPP IPCP Send Configuration ACK
17:30:29, 27 Apr.
(198168.870000) PPP IPCP Receive Configuration Request
17:30:29, 27 Apr.
(198168.840000) PPP IPCP Send Configuration Request
17:30:27, 27 Apr.
(198167.200000) PPPoE is up -​ Down Rate=34993000Kbps, Up Rate=7200000Kbps; SNR Margin Down=15.5dB, Up=21.0dB
17:30:27, 27 Apr.
(198167.190000) CHAP authentication successful
17:30:27, 27 Apr.
(198166.890000) CHAP Receive Challenge
17:30:27, 27 Apr.
(198166.890000) Starting CHAP authentication with peer
17:30:27, 27 Apr.
(198166.890000) PPP LCP Receive Configuration ACK
17:30:27, 27 Apr.
(198166.860000) PPP LCP Send Configuration Request
17:30:27, 27 Apr.
(198166.860000) PPP LCP Receive Configuration Reject
17:30:27, 27 Apr.
(198166.860000) PPP LCP Send Configuration ACK
17:30:27, 27 Apr.
(198166.860000) PPP LCP Receive Configuration Request
17:30:27, 27 Apr.
(198166.840000) PPP LCP Send Configuration Request
17:29:33, 27 Apr.
(198113.100000) PTM over DSL is up
17:28:51, 27 Apr.
(198071.040000) PTM over DSL is down after 51 minutes uptime
17:28:51, 27 Apr.
(198071.030000) PPPoE is down after 50 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
17:28:45, 27 Apr.
(198065.460000) PPP LCP Send Termination Request [User request]
16:38:37, 27 Apr.
(195056.820000) WAN operating mode is VDSL
16:38:37, 27 Apr.
(195056.820000) Last WAN operating mode was VDSL
16:38:35, 27 Apr.
(195055.020000) PPP IPCP Receive Configuration ACK
16:38:35, 27 Apr.
(195055.000000) PPP IPCP Send Configuration Request
16:38:35, 27 Apr.
(195054.990000) PPP IPCP Receive Configuration NAK
16:38:35, 27 Apr.
(195054.990000) PPP IPCP Send Configuration ACK
16:38:35, 27 Apr.
(195054.990000) PPP IPCP Receive Configuration Request
16:38:35, 27 Apr.
(195054.900000) PPP IPCP Send Configuration Request
16:38:33, 27 Apr.
(195053.270000) PPPoE is up -​ Down Rate=34997000Kbps, Up Rate=7199000Kbps; SNR Margin Down=16.4dB, Up=22.5dB
16:38:33, 27 Apr.
(195053.260000) CHAP authentication successful
16:38:33, 27 Apr.
(195053.160000) CHAP Receive Challenge
16:38:33, 27 Apr.
(195053.160000) Starting CHAP authentication with peer
16:38:33, 27 Apr.
(195053.160000) PPP LCP Receive Configuration ACK
16:38:33, 27 Apr.
(195053.130000) PPP LCP Send Configuration Request
16:38:33, 27 Apr.
(195053.130000) PPP LCP Receive Configuration Reject
16:38:33, 27 Apr.
(195053.130000) PPP LCP Send Configuration ACK
16:38:33, 27 Apr.
(195053.130000) PPP LCP Receive Configuration Request
16:38:33, 27 Apr.
(195053.110000) PPP LCP Send Configuration Request
16:37:40, 27 Apr.
(195000.200000) PTM over DSL is up
16:36:56, 27 Apr.
(194956.630000) PTM over DSL is down after 151 minutes uptime
16:36:56, 27 Apr.
<<<<<<<<<<<<<<<<<<<< Limit of wan log >>>>>>>>>>>>>>>>>>>>
16:36:56, 27 Apr.
(194956.620000) PPPoE is down after 150 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
16:36:51, 27 Apr.
(194951.210000) PPP LCP Send Termination Request [User request]
14:06:07, 27 Apr.
(185906.970000) WAN operating mode is VDSL
14:06:07, 27 Apr.
(185906.970000) Last WAN operating mode was VDSL
14:06:05, 27 Apr.
(185905.210000) PPP IPCP Receive Configuration ACK
14:06:05, 27 Apr.
(185905.190000) PPP IPCP Send Configuration Request
14:06:05, 27 Apr.
(185905.180000) PPP IPCP Receive Configuration NAK
14:06:05, 27 Apr.
(185905.180000) PPP IPCP Send Configuration ACK
14:06:05, 27 Apr.
(185905.180000) PPP IPCP Receive Configuration Request
14:06:05, 27 Apr.
(185905.150000) PPP IPCP Send Configuration Request
14:06:03, 27 Apr.
(185903.570000) PPPoE is up -​ Down Rate=34993000Kbps, Up Rate=7200000Kbps; SNR Margin Down=15.1dB, Up=21.3dB
14:06:03, 27 Apr.
(185903.560000) CHAP authentication successful
14:06:03, 27 Apr.
(185903.210000) CHAP Receive Challenge
14:06:03, 27 Apr.
(185903.210000) Starting CHAP authentication with peer
14:06:03, 27 Apr.
(185903.210000) PPP LCP Receive Configuration ACK
14:06:03, 27 Apr.
(185903.170000) PPP LCP Send Configuration Request
14:06:03, 27 Apr.
(185903.170000) PPP LCP Receive Configuration Reject
14:06:03, 27 Apr.
(185903.170000) PPP LCP Send Configuration ACK
14:06:03, 27 Apr.
(185903.170000) PPP LCP Receive Configuration Request
14:06:03, 27 Apr.
(185903.150000) PPP LCP Send Configuration Request
14:05:10, 27 Apr.
(185849.930000) PTM over DSL is up
14:04:25, 27 Apr.
(185805.330000) PTM over DSL is down after 3 minutes uptime
14:04:25, 27 Apr.
(185805.320000) PPPoE is down after 2 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
14:04:20, 27 Apr.
(185799.820000) PPP LCP Send Termination Request [User request]
14:01:26, 27 Apr.
(185625.840000) WAN operating mode is VDSL
14:01:26, 27 Apr.
(185625.840000) Last WAN operating mode was VDSL
14:01:24, 27 Apr.
(185624.090000) PPP IPCP Receive Configuration ACK
14:01:24, 27 Apr.
(185624.060000) PPP IPCP Send Configuration Request
14:01:24, 27 Apr.
(185624.050000) PPP IPCP Receive Configuration NAK
14:01:24, 27 Apr.
(185624.050000) PPP IPCP Send Configuration ACK
14:01:24, 27 Apr.
(185624.050000) PPP IPCP Receive Configuration Request
14:01:24, 27 Apr.
(185624.020000) PPP IPCP Send Configuration Request
14:01:22, 27 Apr.
(185622.430000) PPPoE is up -​ Down Rate=34997000Kbps, Up Rate=7199000Kbps; SNR Margin Down=16.1dB, Up=22.5dB
14:01:22, 27 Apr.
(185622.420000) CHAP authentication successful
14:01:22, 27 Apr.
(185622.140000) CHAP Receive Challenge
14:01:22, 27 Apr.
(185622.140000) Starting CHAP authentication with peer
14:01:22, 27 Apr.
(185622.140000) PPP LCP Receive Configuration ACK
14:01:22, 27 Apr.
(185622.110000) PPP LCP Send Configuration Request
14:01:22, 27 Apr.
(185622.110000) PPP LCP Receive Configuration Reject
14:01:22, 27 Apr.
(185622.110000) PPP LCP Send Configuration ACK
14:01:22, 27 Apr.
(185622.110000) PPP LCP Receive Configuration Request
14:01:22, 27 Apr.
(185622.090000) PPP LCP Send Configuration Request
14:00:29, 27 Apr.
(185569.110000) PTM over DSL is up
13:59:45, 27 Apr.
(185525.250000) PTM over DSL is down after 81 minutes uptime
13:59:45, 27 Apr.
(185525.250000) PPPoE is down after 80 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
13:59:40, 27 Apr.
(185519.810000) PPP LCP Send Termination Request [User request]
12:39:30, 27 Apr.
(180709.930000) WAN operating mode is VDSL
12:39:30, 27 Apr.
(180709.930000) Last WAN operating mode was VDSL
12:39:28, 27 Apr.
(180708.170000) PPP IPCP Receive Configuration ACK
12:39:28, 27 Apr.
(180708.150000) PPP IPCP Send Configuration Request
12:39:28, 27 Apr.
(180708.140000) PPP IPCP Receive Configuration NAK
12:39:28, 27 Apr.
(180708.140000) PPP IPCP Send Configuration ACK
12:39:28, 27 Apr.
(180708.140000) PPP IPCP Receive Configuration Request
12:39:28, 27 Apr.
(180708.110000) PPP IPCP Send Configuration Request
imjolly
Message 3 of 28
is it possible to connect to the test socket instead of the master socket?
have you tried quiet line test to check for line noise?
Jamesvolvo
Message 4 of 28
yes I've tried this with the test socket, same result (I ran it for 2 days)
what do the figures look like to you?
Jamesvolvo
Message 5 of 28
I'd be quite happy to replace the BT HH5 with a router/VDSL modem from a different vendor - has anyone tried this and is it likely to help me?
VirtualEntity
Message 6 of 28
Hi
I had two months of this myself. The good old "PPP LCP Send Termination Request [User request]". Very annoying as it not only downed the connection, but all wireless/wired devices would lose their DHCPd addresses. After several engineer visits where nothing could be found to be wrong and two replacement HHs (A and B), the same thing was happening. Gave up in the end and bought a TP LINK W9980 to replace the HH. Since then the W9980 has not missed a beat - been up for over 3 weeks. Still noticed one or two line drops but the router stays up and the devices maintain their IPs etc. The W9980 isn't as fancy/feature rich as some of the more expensive VDSL router/modems but at less than £70, you can pretty much plug in and forget and chuck the HH in the bin or just put it in the corner and poke fun at it.
Jamesvolvo
Message 7 of 28
excellent, thanks VirtualEntity
so you think that the "PPP LCP Send Termination Request [User request]" is related to the BT hub (or its interaction with the exchange or something upstream) rather than telling that there's a problem with the line?
I don't want to drop £65 on a TP 9980 and then discover that it's actually a problem with the last mile.
I would dearly love to put the HH5 in the bin though...
VirtualEntity
Message 8 of 28
Hi
Can't really answer that but there was clearly something funny with my line and the HH that Openreach/BT were unable to explain/fix. I was provided with an Openreach modem at one point to alleviate the issue and had that in alongside a separate Billion router. That stabilised things but I wanted a single box solution. It was at that point BT sent me a HH5 Type B to try. Within a few hours of plugging that in, I was getting the PPP errors again. It was at that point I'd had enough and bought the W9980. Guess you need to go through the normal process of getting a mod involved and maybe getting an engineer out but if it turns out "there's nothing wrong", ditch the HH.
Jamesvolvo
Message 9 of 28
I'm bored with this, I just ordered a TP 9980. I'll let you know what happens !
nicka99
Message 10 of 28
hi,
my connection is also repeatedly dropping.  I have a new HH5 on its way but not confident it will help as BT have pretty much blamed everything and anything for the last 2 weeks.
Please let us know how you get on with the TP9980
thanks !
nick
