TomBathurst
Message 1 of 6
3rd & 4th Mini Connectors
I purchased a couple of mini connectors and they worked perfectly "out of the box". I've tried to add a 3rd and 4th "pair" and neither will work alongside the original pair. I've tried pressing the (+) button for 8 seconds and then pressing the (+) on another one. I've tried holding in for 15 seconds on all devices - but to no avail.
I assumed that it would be possible to add 3rd / 4th connectors.
Could anyone offer any guidance / advice.
5 REPLIES 5
Welshmatt983
Message 2 of 6
Re: 3rd & 4th Mini Connectors
I managed to get a 3rd paired but cant get 4th, its driving me nuts, can anyone out there help??
JohnC2
Moderator
Moderator
Message 3 of 6
Hi @TomBathurst Welcome to the forum and sorry you are having difficulty adding further mini connectors to your set up.
I have checked the user guide and you are able to add further connectors to the existing pair. The User Guide has the information on how to do this on page 9.
Cheers
John
Oxlade1
Message 4 of 6
Try this:
1. With the original pair you had, Hold + button for 15 seconds to factory reset (lights go off then on again)
2. Make sure these are linked OK with a blue data light
3. Take the 3rd Mini Connector and plug in
4. Press + for 6 seconds on Mini Connector 3, when you let go you should see the lights go off then on again
5. Wait 10 seconds, then press + again on Mini Connector 3 for 1 second - light will start flashing
6. Now press + on one of the original Mini Connectors. Light on MC3 should now be solid blue
7. Repeat 3-6 for MC4
Hopefully this works for you? It helps if you do them all in the same room to ensure they have strong signal when pairing.
TomBathurst
Message 5 of 6
Thanks all - I managed to get it going with the above. Cheers
DavidM
Moderator
Moderator
Message 6 of 6
Thanks for letting us know you're sorted @TomBathurst and thanks again @Oxlade1 for the advice.
Cheers
David
