licquorice
Message 11 of 18
Re: 3rd party router not working anymore
@fretfdust wrote:
@TimCurtis
TimCurtis:
I will try that next but im not 100% sure how to do that, the laptop is running linux mint, while the desktop has windows 7 installed.
On the Linux laptop type ifconfig at a command prompt.
fretfdust
Message 12 of 18
ok typed ifconfig on laptop using both the bt home hub 5 and the asus router, they both gave the same info:
line encap:Ethernet
inet addr:192.168.1.69 Bcast:192.168.1.255 Mask:255.255.255.0
Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
looking at the 192.168.1.254 settings pages on the Homehub 5 and desktop pc I managed to get this information:
Broadband network IP address:    (my ip address here)
Default gateway:    172.16.18.3
Primary DNS:    31.55.186.78
Secondary DNS:    31.55.185.46
Ethernet: ip address: 192.168.1.67
Hub IP Gateway Address
IP Address:    192.168.1.254
Subnet mask: 255.255.255.0
licquorice
Message 13 of 18
What do you get for netsat -nr on the laptop?
licquorice
Message 14 of 18
You should get 192.168.1.1 as the Gateway when connected to the ASUS and 192.168.1.254 when connected to the Hub. Are you using DHCP everywhere or have you given anything static addresses?
scott_johnston
Message 15 of 18
Maybe a daft question but when you installed the Asus did windows recognize that you are connected to a new network in the network and sharing center or is it using the same one?
fretfdust
Message 16 of 18
it tries to use the same one scott.  Keeps saying connecting... disconnected.. over and over. using the windows troubleshooting it then tells me that no cable is connected.
I'll do what you suggested now
fretfdust
Message 17 of 18
on the home hub:
Destination 0.0.0.0 192.168.1.0
Gateway 192.168.1.254 0.0.0.0
Genmask 0.0.0.0 255.255.255.0
Flags UG U
on the asus router:
Gateway 192.168.1.1 0.0.0.0
Flags UG U
I never setup any static IP addresses for anything on the network, I noticed DHCP is turned on on the Home Hub, im pretty sure it is on the Asus router as well.
edit: looking at the asus router settings now using the laptop:
LAN - LAN IP
IP address: 192.168.1.1
Subnet Mask: 255.255.255.0
LAN - DHCP Server
Enable DHCP Server: Yes
RT-N56-U Domain name: (blank)
IP Pool starting address: 192.168.1.2
IP pool ending address: 192.168.1.254
Lease Time: 86400
Default Gateway: (blank)
DNS and WINS server setting
DNS Server: (blank)
WINS Server: (blank)
Enable Manual Assignment: No
WAN - Internet Connection
WAN Conbnection type: PPPoE
Enable WAN: yes
Enable NAT: yes
Enable UPNP : no
get the WAN IP automatically: yes
connect to DNS server automactially: yes
Special requirement from ISP
Enable VPN and DHCP connection : yes
Host name: blank
MAC address: blank
Extend trhe TTL value: no
anyone jumping out at you there? should I perhaps find out the MAC Address of the desktop and then try to manually assign it an IP address on the LAN ?
typed the below on the desktop to find my MAC address:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\fretfdust>ipconfig /all | more
Windows IP Configuration
Host Name . . . . . . . . . . . . : fretfdust-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : (my MAC address here)
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Tunnel adapter isatap.home:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
-- More --
licquorice
Message 18 of 18
Your local network looks fine, it looks as though your ASUS is not connecting at the PPP level. Have you entered the correct details since you did the factory reset? Username homehub@btbroadband.com, password bt. VLAN needs to be set to 101
