Park_Ranger
Message 1 of 73
4 months and still rubbish.....
Posted on this forum some time ago with reference to a slow and unreliable connection.
Contacted the mods as suggested and then had 2 enginner visits and a new hub about a month ago.
Problems with a slow connection and hub rebooting continue.
Hub has rebooted this month........
17:15 Jul 1st
18:30 Jul 1st
12:20 Jul 2nd
17:00 Jul 3rd
19:00 Jul 3rd
05:30 Jul 4th
12:00 Jul 5th
12:15 Jul 5th
15:00 Jul 5th
15:00 Jul 5th
11:00 Jul 11th
19:30 Jul 11th
08:15 Jul 12th
17:00 Jul 12th
23:00 Jul 12th
20:00 Jul 14th
23:00 Jul 14th
18:30 Jul 17th
21:00 Jul 17th
23:00 Jul 17th
08:00 Jul 18th
Line noise varies from as low as 1.4 up to about 7
Connection generally about 1125k, (Profile 1000k after a few hours), sometimes get stuck at 480k (Requiring a manual reboot to get the line speed up, not included in above reboots).
Due to the number of times the hub reboots the profile is usually low, 350k
There was talk of a "Rein" engineer looking at it as a previous engineer though there might be interference causing the hub to reboot, but they sent a new hub instead.
So whats my next step ?
This is rubbish and not the kind of support I expected from BT.
72 REPLIES 72
Moderator
Moderator
Message 2 of 73
Re: 4 months and still rubbish.....
Hi Park_Ranger
Sorry to hear that problems are still ongoing. I have just sent you an email, I'd like to pick up this case again.
Stuart
Community ModeratorStuartH
Show your appreciation!
Kudos”Kudos”
Park_Ranger
Message 3 of 73
Yeah BT just called, there's nothing they can do. (Great news eh ?).
Because of the distance from the exchange, I just have to put up with the hub re-setting when it feels like it (A couple of times a day).
No point in sending out any more engineers.
My only option according to the guy that called is to wait for FTTC, and thats a couple of years, at least, away for us.
My connection with Tiscali over the same BT line was faster and more stable, you couldn't make it up !
I'm disappointed.............
And to add insult to injury, I just had a BT flyer drop through the door............
"Be one of the BETTER CONNECTED"
Very funny.
Park_Ranger
Message 4 of 73
Stuart "
Yeah that went well Stuart...........
gouledw
Recognised Expert
Message 5 of 73
You know, might be some help if you put your trust in Stuart and respond to his e-mail if you haven't already. 🙂
Park_Ranger
Message 6 of 73
Of course I responded to Stuarts email about helping on this forum.
The call from BT came after the my email was sent, and I would assume (As before) was a call as a direct result of my post and Stuarts intervention on this forum.
Well thats how its worked before, post here, mod replied and emailed me, I reply to mods email, BT call by phone.
A Scottish chap by the name or Richard.
Park_Ranger
Message 7 of 73
Think I just saw a tumbleweed blow across this post.............
It seems Stuart has fallen off the face of the planet......................
Hub continues to reboot of it's own accord at least once a day, difficult to maintain any sort of reasonable profile.
And I find BT's attitude quite shocking, thats as good as it's going to get, you have to put up with it.
I'm still paying full price for this less than satisfactory connection.
Community Manager
Community Manager
Message 8 of 73
Hi Park_Ranger,
If you haven't already, send us another email and we'll get back to you on this.
Thanks,
Stephanie
Community ModeratorStephanie
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Park_Ranger
Message 9 of 73
Hi StephanieG can you post me a link, the last email to Stuart I replied to (After BT called) was unanswered.
Thanks.
Community Manager
Community Manager
Message 10 of 73
If you click on my username you'll be able to get our "Contact Us" link. It's under "About me" (top-left of the page).
Ta,
Stephanie
Kudos”
