raymie67
Expert
Message 71 of 73
Re: 4 months and still rubbish.....
Well the nearest REIN engineer to me comes from around a 2 hour drive away, came and at no time has that junction box ever been mentioned to me, it makes me wonder if either they people here have missed a stage or if that box is not really of much use in some situations.
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
gouledw
Recognised Expert
Message 72 of 73
Are you sure theres only two? Because I've had 2 out at the same time with the area coach and area manager to try and try and fix the faults.
Park_Ranger
Message 73 of 73
"Are you sure theres only two?"
Nope, just going by what the last couple of engineers said.
