Message 1 of 5
4K/Ultimate no longer working on Fire TV
In the BT Sport app on my Amazon Fire TV Stick 4K Ultimate, the BT Sport Ultimate channel disappeared around a week or so ago.
Using the Compatibility Checker, there is a cross (X) for 4K on the "Devices" row:
"Your Fire TV and your TV are not able to display 4K. If you think this isn't right, visit http://bt.com/sport/help"
I tried to visit that page but it says "Sorry, we couldn't connect you":
What can I do to fix this and get 4K/Ultimate back on BT Sport app for Fire TV?
It was working perfectly well until a week or two ago, with the exact same devices (4K Fire TV Stick with 4K LG TV). I have tried restarting the Fire TV Stick, and also powering off and turning back on both the Fire TV Stick and the TV, but to no effect.
Thanks in advance!
4 REPLIES 4
Message 2 of 5
Re: 4K/Ultimate no longer working on Fire TV
Check your display settings on the Fire Stick - Settings, Display & Sound, Display, Video Resolution.
If you've manually selected a value below 4K, then it'll prevent the app from displaying 4K.
I've also notified the app team of the incorrect link to bt.com - it should have been /help/sport not /sport/help
Message 3 of 5
Thank you, @DarrenDev - that has solved it, probably the fastest I've ever had an issue solved on forums like this! 😀
It was set to 1080p for some reason; I don't think I changed it myself so can only think the Fire TV Stick changed it when I watched some non-4K content.
Message 4 of 5
@adw it could have been a software update from Amazon that reset your screen resolution...
Message 5 of 5
I could only access HDR , not 4K HDR for the Chelsea match when I switched  on for k.o today. I normally have display settings set to up to 4K with match original frame rate set to ON. I have now changed my display settings to 2160p/50Hz in order to be able to access the match in 4K HDR.
