Message 1 of 5
4g not working on Honor 10 after update
This morning my Huawai 10 completed an update which I believed changed the Android version.
It appears that since then the Mobile Internet no longer works - It finds the network, connects both on BT 4G (and 3G) but there is no data symbol.
Tried to restart, change config, everything, but no success.
Anyone else having this problem?
4 REPLIES 4
Message 2 of 5
Re: 4g not working on Honor 10 after update
Hah, simple fix.
It seems the APN disappeared after the Update - adding the EE Internet APN solved it.
Message 3 of 5
I had the same problem.
Just manually enter a new APN into your honor 10 from the network settings options.
APN: everywhere
Proxy: Not Required
Port: Not Required
Username: eesecure
Password: secure
Server: Not Required
MMSC: http://mms/
save and highlight the internet option you have just set.
Message 4 of 5
This just worked for me.  On my Honor Play, after it updated to Pie (Android 9), my 4G disapeared and nothing I reset, or tweaked could get the 4G back.  Calls and texts worked, other SIMs worked but this one just wouldn't budge.
Go into Settings>Wireless and Networks>Mobile Network>Access Point Names, then hit the three dots in the top right for the menu and chose "New APN".  Enter these settings....
APN: everywhere
Proxy: Not Required
Port: Not Required
Username: eesecure
Password: secure
MMSC: http://mms/
save and then make sure "EE internet" is the choice selected.  You should have you rmobile data back.
Message 5 of 5
Snap!
