Message 11 of 22
Re: 50% slower sync speed since moving to BT
So how do I get back to where I was with my previous provider, short of ditching BT and going back to them?
Message 12 of 22
So I need to get back to the ADSL2+ that was on my LLU product with my previous provider. This worked perfectly ok on my long line.
Expert
Message 13 of 22
@john46 wrote:
the LLU connection was ADSL2+ you are now on ADSLMAX that is likely to explain the speed difference you are on a long line which will never achieve a fast connection
Hi john46,
Please excuse the interuption but I am always trying to further my understanding.
You, and others, have always said that ADSLMax was likely (never said certain) to provide a faster downstream speed than ADSL2.  As you know this proved to be the case for me but only marginally, not making it worth moving back for, especailly in view of the about double upstream speed.
However, on this topic you are now saying the OP's speed reduction is due to the move from ADSL2 to ADSLMax.
Why the difference please ?
Best regards,
dfenceman
Message 14 of 22
LLu services use ADSL2+ technology he has now moved to ADSL max since joining BT
Message 15 of 22
John46, I believe that much was obvious from your previous text. I think both I and dfenceman want to know a) why the difference in speed technically and/or b) why the difference in advice when dfenceman was told ADSLMax would be quicker but for me the implication is that it SHOULD be slower.
Also, do you know if it's possible to get moved back to ADSL2+ seeing as this was the quicker technology for me?
Message 16 of 22
with your attenuation on the router showing as 63.5 and if correct then that should give a conenction speed of 1.9/2mb whether on adslmax or adsl2.  However 63.5 is as high as many router show so if your true attenuation is greater than 63.5 which from your speed seem reasonable then it is difficult to be sure what your best conenction speed can be.
your can see from the kitz speed link that depending on your attenuation over 63.5 the lower the conenction speed gets and there is little difference between adslmax and adsl2.
with adsl2 you get a higher up speed (2X) but adsl2 also has a more aggressive system on line noise so on long lines there is more likely chance of line noise and therefore more chance of errors and connection drops.
it may be possible for the mods to get wholesale to move you to adsl2 but I would read the latest posts from dfenceman before you decide
check speed
Message 17 of 22
This is a link to the Forum Mods  http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3/5 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 18 of 22
So there seems to be a difference of opinion here. 1 person says it shouldn't make too much difference between MAX and 2+ and 1 person reckons it should???
Talk about confused.com!!Man Sad
So the root issue is, what has caused this drop of sync speed between 1 provider and another, I can then tackle the issue with the correct framework
Message 19 of 22
if you use the check speed link you will see the small difference in conenction speed if adslmax or adsl2
Message 20 of 22
Have contacted the forum mods to see if they can escalate this issue.
Whilst I appreciate all your valued inputs I am of the conclusion that testing speed is not going to resolve why, with BT as my provider, my downstream sync speed is 50% slower since moving ISP.
I will of course keep all posted on the findings/conclusions.
