Submariner
Message 21 of 33
Re: 58k!
thanks for your help.....
Submariner
Message 22 of 33
Re: 58k!
Download speedachieved during the test was - 2721 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :3744 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 3000 Kbps
This is the latest test result. I assume that 2721 is the fastest I am going to get? despite being told it should be between 6-8 mb
Message 23 of 33
Re: 58k!
can you post the adsl stats again
I think you should have a better connection speed which in turn will give better profile and download speed
Submariner
Message 24 of 33
Re: 58k!
Downstream:3.594 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):14.5 dB / 24.0 dB
Line attenuation (Down/Up):24.5 dB / 12.5 dB
Output power (Down/Up):19.7 dBm / 12.2 dBm
FEC Events (Down/Up):14465 / 0
CRC Events (Down/Up):2 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):20 / 0
Error Seconds (Local/Remote):1 / 1
Message 25 of 33
Re: 58k!
noise margin is high at 14.5 instead of normal 6
what is the connection time as it is missing
Submariner
Message 26 of 33
Re: 58k!
About 20 minutes as we have just re-organised the living room, prior to that it was about 4 days.
Message 27 of 33
Re: 58k!
are you still connected to the test socket or have you moved it to somewhere else after the reorganisation?
Submariner
Message 28 of 33
Re: 58k!
Still connected into the test socket. Darent move it!!!
Message 29 of 33
Re: 58k!
then as it now looks good I would email the mods and ask for your noise margin to be reset to 6 which should give the increase in speed
can take a few days for mods to get back to you
Submariner
Message 30 of 33
Re: 58k!
Download speedachieved during the test was - 2734 Kbps
 Your DSL Connection Rate :3680 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
The latest readings this morning.
Once again many thanks for your help Jolly. Genuinely appreciate it.
