Message 1 of 3
5ghz to 2.4ghz
I've bought a bird box which needs to be set up on 2.4ghz, I've got a BT Hub6 how easy is it to set up the 2.4ghz please, bear in mind I'm not overly technical! is it easy please?
2 REPLIES 2
Message 2 of 3
Re: 5ghz to 2.4ghz
If you have a hh6 then
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
After you have done that and given 2.4ghz different SSID then connect bird box to that   Should be no problem
Message 3 of 3
Re: 5ghz to 2.4ghz
lovely thanks everso
