Welcome to this forum.
This is a customer to customer forum only,
This is where customers help each other get the most out of BT products & services.
Anything you post here does not go to BT. Although the forum is moderated by BT, not all posts are read.
Everyone posting here, are just BT customers like myself
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Try the The broadband technical helpdesk
Have you checked the BT Service Status?
http://bt.custhelp.com/app/answers/detail/a_id/15036/%7E/service-update
See if your exchange code shows up on this page https://status.zen.co.uk/broadband/
This tends to give more info that the BT one, and may indicate what the problem is.
Then its affecting more than one customer, and possibly other ISPs. There is not much you can do until the problem is resolved.
You can claim compensation once the fault is fixed.
http://bt.custhelp.com/app/answers/detail/a_id/9394/%7E/customer-service-guarantee
You wouldn't be in the GU11 1NJ area would you?
If so the cabinet was damaged and required a re shell (I presume vehicle impact), fibre and copper to be reconnected (ongoing).
Re shell done & temp service is being restored awaiting power to be reconnected. Should be completed later today.
If you enter your phone number HERE it will tell you which cab you are connected to.
The cab affected is cab 13.
