Message 1 of 3
6023 on Netgear AC2600
Hi,
Having no luck at all with this.
BT Sport channels are working fine on Hub 6.
But I want to use my own Netgear Router.
I have unticked Disable IGMP Proxying and ticked the Support British Telecom (BT) IGMP Proxying.
I have tried setting the DNS on the Youview box to be the same as the routers.
Mixed results all round went from 30 seconds to getting 20 mins and now can't get anything at all just straight to the error.
Any ideas?
2 REPLIES 2
Message 2 of 3
Re: 6023 on Netgear AC2600
Actually got this working setting router and box to Google dns.
The current setup is running a wire through the house. Does anyone know a Network switch which is compatible?
Message 3 of 3
Look at this page for the answer Problems sharing the signal to the YouView box with other devices.
You will need to connected to BT Broadband to access any links I post which are hosted on my website..
If you are connected to BT Broadband, and you cannot access them, then please let me know on this thread. Thanks.
