Mazz71
Message 1 of 7
7 day catch-up does work on Premium channels?
Hi,
I'm a new user of the BT TV Youview box (UHD).
All set-up apart from my freeview aerial (thats being done on Friday).
Just checking out the Premium channels (Nat Geo, Discovery etc).
The 7 day catch-up. As soon as I start to scroll back.....
The OK button says not available. Is this how it works? 7 day catch-up on Freeview only?
I hope someone can help?
Matt
6 REPLIES 6
dale
Message 2 of 7
Re: 7 day catch-up does work on Premium channels?
This is what I do , press bt vision button , when enter comes on the screen press ok on your remote , scroll down to catch up then scroll a cross and press ok on tv players and lot of it is there . Hope this helps .
dale
Message 3 of 7
My box is a youview box only it might be different setting on your box
zulu17
Distinguished Guru
Distinguished Guru
Message 4 of 7
Selecting BT Player then
Catch Up > TV Players
will give you option to look thru the catchup for about 23 of the BT TV channels. (for Kids and sports see below}
also
Library   ->AMC will give you AMC content (Note this is mostly the same as that to be found under the AMC Catch Up player)
>BT Sport - will give you the available BT Sport prorammes
>Kids - will give you all the available Kids programs
>A taste of On demand  - lists a few programs that BT normally allow for free viewing.
Some channels do not have any on demand or catchup  - for example (British) Eurosport.
Mazz71
Message 5 of 7
Thanks all.
So, it looks as if the 7 day catch up is only available on the freeview channels.
Well, at least I know.
Cheers
Matt
zulu17
Distinguished Guru
Distinguished Guru
Message 6 of 7
I think there is a bit of confusion here between catchup tv and 7 day scroll back that Youview often highlights in its product advertising.
Youview  has a 7 day scroll back TVs guide which links the programs to the psb players.. I'e BBC Iplayer , ITV hub , all 4 ,demand 5. The actual time programs are available to watch on catch up varies and some programs may not be available depending upon the rights the broadcaster has and the broadcasters own decisions.
Other players some free like UKTV player and Quest also offer catchup as does the BT Player with your subscription.
Mazz71
Message 7 of 7
Thanks Zulu.
You've answered by question.
Nice one
Matt
