Message 11 of 16
Re: 70kbps download speed :(
It used to be. It's recently been reduced to 1 per hour.
Message 12 of 16
Just found out it's the top image from the socket images (copy and paste gives me an image placeholder instead of the image so can't repost it)
If it helps, I'm connected to the test socket directly (removed the faceplate, bottom right socket) to eliminate any sources of interference for the purpose of these tests, as I always do for the best possible speeds.
sh77
Message 13 of 16
hi could you now repost your hub stats at the test point please
Message 14 of 16
sh77
If you have any extensions that you need working for your phones, you can connect it up as per the photo below.
Message 15 of 16
Hmm.... 3.4Mbps DL now and 39ms ping. Am I speaking too soon by saying "It seems to be fixed, woo-hoo!"?
We'll see later on I guess when it reaches peak time.
Many thanks for all the useful replies - you've saved me the frustration of dealing with call centre staff.
Message 16 of 16
could you please post the full results of the bt speed test
speedtester.bt.com
