emuholic
Message 11 of 108
Re: 75mb to 3mb...
It changed when I reset the homehub. 86.145.XXX.XXX to 86.173.XXX.XXX.
Update: I am on the Upton Park exchange.
55brianb
Message 12 of 108
Re: 75mb to 3mb...
Yea problems here too (using the Bowes Park exchange) - connection dropped for half an hour last night and today is, according to the BT speedtest:
Download speed: 4.61
Upload speed: 7.65
Ping: 73.38
Slower than my old broadband.
Distinguished Expert
Message 13 of 108
Re: 75mb to 3mb...
@emuholic do you get the same speeds wired or wireless?
Adlopa
Message 14 of 108
Re: 75mb to 3mb...
Bowes Park exchange here, too...
Message 15 of 108
Re: 75mb to 3mb...
@55brianb what does your ip profile give you?
emuholic
Message 16 of 108
Re: 75mb to 3mb...
Same speed on wired and wireless, tried with 2 different PC's.
Message 17 of 108
Re: 75mb to 3mb...
have you tried different lan sockets on the homehum?
55brianb
Message 18 of 108
Re: 75mb to 3mb...
@Bullitt
Sorry, I don't khow where to get this info.
Guru
Message 19 of 108
Re: 75mb to 3mb...
goto http://speedtester.bt.com/ and take the 'ADSL and Fibre Diagnostics' test.
Or, a bit quicker but less official, goto http://windows.mouselike.org/be/?DoAction=BrasChecker
By the way: the ip profile reported by speedtester is the same thing as the BRAS rate reported from the BrasChecker.
Message 20 of 108
Re: 75mb to 3mb...
@55brianb (isnt this forum software useless! is there any concept of threads?) you get your ip profile by running speedtester.bt.com and choosing the adsl/fttc diagnostics button
