Message 1 of 5
80/20 Ordered on 12 & was activated the next day but speeds now dropped
Ok rebooted hh on fri the 13,speeds shot up to 66mb down 16 up,great 🙂 till this morn,now the download speed keeps dropping randomly 20 around 20-24mb,not happy,10 days is up tomo,was getting full download before the upgrade.
4 REPLIES 4
Message 2 of 5
Re: 80/20 Ordered on 12 & was activated the next day but speeds now dropped
OK just done another speed test and it's back to 66,16,so erratic,guess i'll just wait til tomo and see what happens.
Message 3 of 5
Don't beleive everything the speedtests say. They are not reliable at all, if you purchased broadband to stare at speedtests all day then you have no life. Do some real downloading and appreciate your speeds !!
IT SUPPORT TECHNICIAN - Comptia A+ Certified, MTA Qualified and MTSC qualified
Guru
Message 4 of 5
Many users on the forums are experiencing erractic speeds but actual throughput mostly seems to be ok.
Hopefully over time this was all settle down and everybody speed tests should be fine.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 5 of 5
Im aware of the irregularity of speed testing however when it drops to like 20 thats an obvious problem which has never happened before for me on either speedtest.net or bbmax,will see what happens over time when it settles Aarong.
