Message 11 of 15
Re: 80%+ Packet Loss on a BT hop!
intermittent spikes are almost impossible to trace and your tracert shows no fault
Message 12 of 15
If you run the following command in a cmd prompt it may should show ping spikes. Best to run it on a wired connection
ping -t bbc.co.uk
Message 13 of 15
Is that an admission on these forum boards that an interleaved line (a technology usually used by BT to compensate for last hop dodgy wiring) - which leads to erratic spikes in ping latency - that may ....
A) Make Games Unplayable
B) Cause Random Buffering of Streaming Services
C) Cause other server disconnections like FTP and Live Consol Monitoring
Just wondered - I thought we were being sold super fast (the best in Britain) services.
Message 14 of 15
Getting exactly same issues. Started about 2 weeks ago.
Message 15 of 15
interleaving is placed on the line at the cabinet by the DLM not the last hop it is applied if the line errors climb to a level high enough to cause line instability
