stelee
Message 1 of 16
A Weird Speedtester http://www.mybroadbandspeed.co.uk/
Probably the most random speedchecker at the moment.
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------BT Infinity 2 | 80/20 | SamKnows™ Infinity 2 Member | (EASBF)
Stephen
15 REPLIES 15
Message 2 of 16
Re: Good speedtester! http://www.mybroadbandspeed.co.uk/
ok for up to 10mb not for anything faster
martpu
Expert
Message 3 of 16
I just took 2 tests immediatley following each other.
The first gave me a DL of 27mb and the second 37mb?!
Edit: Took a third which was 26mb?!
Is it the speedtesters that are inaccurate or can our broadband speeds really flucturate by so much over such a short time span?!
________________________________________________________________________
You won't get to ride the racehorse...until you've ridden the mule.... - RogerB 13/04/2010
D-ave
Expert
Message 4 of 16
@stelee wrote:
Probably the most reliable speedchecker at the moment.
Reliable?
I think not.
Message 5 of 16
Just got a result of 17.8up so it's alright 😉
stelee
Message 6 of 16
Ive re prhrased this thread as you may notice,
I should have  said only for my connection lol
Stephen
Message 7 of 16
The download on that site wasn't magic. I done 10 tests in a row and never got above 45. www.speedtester.bbmax.co.uk gives 73.7 down and 11.5 up.
http://www.speedtest.bbmax.co.uk/results.php?t=1333475480&v=15437308
Just goes to show that different sites and servers will give differing results! I personally never test the speed unless something isn't working 🙂
stelee
Message 8 of 16
Yes, shall we come to a conclusion that all speedcheckers are c(r)ap.
Stephen
Message 9 of 16
I wish other people would agree! Would save lots of bother haha.
Seriously, if the internet is working for what you're doing, why be bothered what "number" it is!
martpu
Expert
Message 10 of 16
That test certainly gives far more consistent results Webby.
