legitimise_sailing
Distinguished Expert
Message 11 of 19
Re: A couple of self-install questions
I don't see why not.
To say thanks for a helpful answer, please click the white star
groovychris
Message 12 of 19
By 'Broadband Extender Flex', I actually meant the Broadband Extender Flex 500 which is part of the Wi-Fi Home Hotspot 500 Kit.
So, the arrangement I have in mind, is that the Home Hub 5's power supply would go into a socket extension lead like the one pictured above (with a laptop also plugged into it), and then the socket extension lead's plug would go into the Broadband Extender Flex 500's pass through socket, with the Broadband Extender Flex 500 plugged directly into the nearest wall socket.
Then upstairs, I would have the Wi-Fi Home Hotspot 500 in an unoccupied plug close to my desktop.
Would this arrangement be likely to work?
Deathtrap3000
Recognised Expert
Message 13 of 19
That will work fine. They are designed to cope with loads a lot greater than that.
RobbieMac
Moderator
Moderator
Message 14 of 19
Moved:
Helios
Message 15 of 19
He's winding you up Deathtrap, no one is actually that thick! Then again?!?!
Rottie
Recognised Expert
Message 16 of 19
** Walks in and hammers up a "Please don't feed the trolls" sign on the virtual wall ** 😄
groovychris
Message 17 of 19
Edit: Misinterpreted above post (about the troll).
groovychris
Message 18 of 19
How many amps does the Home Hub 5 use?
Also, what's the maximum number of amps you can plug into the Broadband Extender Flex 500's pass through socket?
pippincp
Sage
Message 19 of 19
See rating plates on devices.
